Originally Posted by Al_S
MAF = Mass Air Flow sensor?
Is that seviceable to clean or as a component replacement?
I also read about throwing the code due to intake manifold gasket leak from sub-freezing weather.
Any way of diagnosing this?
MAF is serviceable:
http://matrixowners.com/index.php?showtopic=65513
MAF cleaner is $7 at an autoparts store. You are supposed to disconnect the battery before cleaning and that will clear your CEL. It is very delicate do not touch it with anything besides the cleaner. How is your mileage?
Intake manifold is a possibility, when the CEL came on last time, was it cold out? To check for a leaky intake manifold gasket, spray the area around the intake manifold gasket with carb cleaner while engine is at idle. If you hear the engine rev, you found the problem.
