CEL Code P2610: MYSTERY...HELP
So I get a check engine light the other day. I hook up my OBDII reader and out comes code P2610. Apparently it's for "ECM/PCM Internal Engine Off Timer Performance- rare code."
Everywhere I read it basically says I need to replace the ECM. Also, everywhere I read, whenever people have experienced a bad ECM it's associated with the car just powering off, dying. There seems to be significant problems with the car's functionality when the ECM is bad.
Here's the mystery......this car runs PERFECT! PERFECT idle, everything is smoooooooth. I just drove it 65 miles to work in stop and go and freeway riding at a consistant 85mph for miles and miles. No problem whatsoever.
So for fun I swapped in a new PCV valve (needed it bad), thoroughly cleaned off the MAF sensor with MAF cleaner, cleaned out the throttle body/butterfly, made sure my gas cap was tight, cleared the code and it came back. I cleared the codde again this morning and 65 miles later or one time turning onthe car...so far no code.
How can I get a P2610 code, saying the ECM is having problems and have NO manifestation of problems whatsoever?
2005 Toyata Corolla LE
