Originally Posted by jdimas29
I do NOT have L.E.D tail lights..... Why do you ask? Just curious. I will call them per your advise. Thank You!
The Corolla Altis taillights that can be swapped into the corolla and can confuse the ECU, it has to do with low voltage I believe and set off the codes for a bad ECU. But toyota put out a bad batch of ECUs during 2006 and if you are sure it is a bad ECU then replace it. I take it your car was made in CA? Most of the ECU problems are from automatic cars made at the Toyota CA plant. I believe Delphi made them. Denso (Toyota OEM) also makes ECUs for the corolla, I would be curious if your replacement is a Denso unit.
Also mention that your car is driven in CA, not sure if a different ECU is needed for the strict CA smog laws, but it is worth asking. If you are positive that the above part number is correct, there should not be a problem. They may also give instructions on how to swap it out. I believe they can enter the VIN into the ECU before shipping it to you, but I am not sure.
I believe parts and labor at the dealer for a new ECU is upwards of $800.
