electric problems== help please- - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2010, 04:51 PM   #1 (permalink)
View jamesmetairie's Photo Gallery
2003 vibe and 2004 corolla. on the vibe the other day license plate blub was shaking loose so i stuck some aluminum paper down in the socket to tighten it. blew a fuse. replaced the fuse. and installed new blub and all was o k . next day one front head light was not working. today i bought a head light blub. now before i could insatll it i notice "both" head lghts will not work in "day time driving" and also will not work when i turn on the head lights using the "stalk". i tried with the engine running in drive and reverse,etc. BTW - corolla book says to actually take the car to the dealer for license plate blub replacement or you could screw something up. maybe i did !!! any advice will be appreciated .thanks guys.
6&8.
jamesmetairie is offline   Reply With Quote
Old 01-24-2010, 05:09 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532067
By both head lights to you mean all 4 head light bulbs or both as in the left side bulbs don't work? I would check the relay and the socket connections.
mikered30 is offline   Reply With Quote
Old 01-24-2010, 05:35 PM   #3 (permalink)
both regular"drl"
day time driving lights do not automatically light up when i start the car and put it into drive as of today. also i tried to turn on the head lights using the stalk and they will not light up either. i do have the circular amber lights woking towards the outside of the lenses assembly. i can flash the "bright lights" to the on position and they stay on o k . all the rear lights,etc. seem to be o k .
car is parked in a car port and there,s plenty of day light outside. i,m waiting to see what will happen later tonight. the blubs are sylvania plus 30%. thanks.
6&8.
Old 01-24-2010, 08:52 PM   #4 (permalink)
after dark same thing.
no change after dark.
6&8.
Old 01-29-2010, 11:54 PM   #5 (permalink)
problem cured=
it surprised me. i changed both front headlights and all is well. sure thought it was gonna be something weird.
6&8.
Old 02-01-2010, 10:14 PM   #6 (permalink)
View chriscorolla's Photo Gallery
That's odd that BOTH headlights went out at basically the same time.
chriscorolla is offline   Reply With Quote
Old 02-02-2010, 12:19 AM   #7 (permalink)
apparently it did happen.
but i,d bet that the blown fuse had something to do with it. and i was getting ready to spend big bucks at the dealer or auto electric shop. wow. sometimes the simple things work.
but don,t ever use aluminum paper in a fuse box . reminds me of the time out camping when i tried to use a potato chip bag for toilet paper. it didn,t work either.
6&8.
Old 02-04-2010, 12:26 PM   #8 (permalink)
View tarbasd's Photo Gallery
You probably shorted the system with the aluminum foil, and that may have done something with the headlights.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
