Check engine light - 4 codes
I have a 2005 Corolla CE and recently, had to change the ECM after the car shut down on me. Not even a month after changing the ECM, I am getting the check engine light (again). I took the car to advance auto parts to get the codes myself and I got the following 4 codes:
- P0741: Torque Converter CKT Performance or stuck off
- P2111: TAC System stuck open
- P2112: TAC System stuck closed
- P2119: TAC throttle body range/performance.
Has anyone ever had these? If so, did you have them all at the same time? I took the car to the dealership to get it checked out. They are telling me that I need to have the throttle body replaced and they are quoting me nearly $1200 to replace. I'm not so sure the throttle body needs to be replaced, but I could be wrong. The car seems to drive fine. I just don't want to have it shut down on me like it did with the ECM issue recently. Anybody have any ideas or suggestions? Think it could be a faulty ECM? I don't know too much about cars, so any help would be greatly appreciated.
Oh yea, my car has about 94k miles. I believe my car would not qualify for any Toyota warranties at this point, which I found out the hard way when replacing the ECM. Thanks for your help and input.
