Originally Posted by jmforem
Thanks Dorman68. Do you know what the TSB number is? I searched through the titles, and none jumped out as being the one you mentioned.
tsb - EG045-07
Title:
M.I.L "ON" DTC P0171, P030#,
AND/OR P0133 ENGINE RUNNING
LEAN IN SUBFREEZING AMBIENT
TEMPERATURES
Models:
'03 - '08 Corolla & Matrix (1ZZ-FE)
October 27, 2007
Introduction
Following a cold soak in subfreezing ambient temperatures, some 2003 - 2008 model year Corolla and Matrix vehicles equipped with a 1ZZ-FE engine may exhibit a M.I.L. "ON" with one or more of the following Diagnostic Trouble Codes (DTCs) as the result of a vacuum leak at the
intake manifold.
^P0171 - System Too Lean (Bank 1)
^P0300 - Random Multiple Cylinder Misfire Detected
^P030 # - Cylinder (1-4) Misfire Detected
^P0133 - Oxygen Sensor Slow Response (Bank 1 Sensor 1) Please use the following procedure to repair the vehicle.
Applicable Vehicles
^2003 - 2008 model year Corolla and Matrix vehicles equipped with the 1ZZ-FE engine
