a way to take off the Autoheadlight? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2010, 03:53 PM   #1 (permalink)
View Broke_azz_baller's Photo Gallery
I have a 07 corolla and I was curious if there is anyway to disengage the auto headlights on function. I was told i can try to take out the plug with the autolight function (not sure what the name exactly said i have it on a slip of paper) but when i did that the headlights didnt even turn on or wouldnt turn on...
Does anyone know what I can do to make it so i can turn on my headlights manually and not have it automatically come on?
Thanks
Nick
Team Top Rated
Broke_azz_baller is offline   Reply With Quote
Old 02-19-2010, 04:10 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $271875
View TrdSpeed140's Photo Gallery
you can put a switch in there... that's the easiest way i think
TrdSpeed140 is offline   Reply With Quote
Old 02-19-2010, 04:52 PM   #3 (permalink)
can you explain what you mean by " put a switch in there"
thanks
Team Top Rated
Old 02-19-2010, 05:07 PM   #4 (permalink)
ok, well what do you know about automotive electrical wiring? are you "do-it-yourself" inclined at all? you could find a wiring diagram for the headlights and wire in a relay and switch so you can control when they turn on. it may be a tad more complicated than that, i don't know for sure maybe someone else will chime in who has actually done something along these lines, but that's basically how you could do it.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
Old 02-20-2010, 12:54 PM   #5 (permalink)
yea im DIY guy...Have my own shop...just dont really feel like cutting wires n shit incase i do deside to sell the car and get something bigger incase my family expand..
Team Top Rated
Old 02-21-2010, 01:44 AM   #6 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
if you are broke, there's always one click up on the e-brake...
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 02-21-2010, 05:58 AM   #7 (permalink)
Adama's Avatar
View Adama's Photo Gallery
Find the DRL (daytime running light) module located above the brake pedal. Find “Pin #12”. It is the red/white (red with white strip) wire closest to the lable on the DRL module and closest to the big pair of wires coming out of the module. Follow the wire about 2 inches down from the DRL module and cut the red/white wire. Now you no longer have DRL and the lights will only come on when the switch is turned on. If you want, you can splice a wire to the ones you cut and run it to a switch to active the DRL whenever you want or add a spade connector and reconnect the wires when needed.
This works with the US built Corolla’s.
H&R Race Springs / 09 Xrs Rims / TRD F & R Sway Bar / TRD FSB / Alutec RSB
Avic Z3
/ Tc Center Armrest / Tc HomeLink Mirror / Valentine 1 / ScanGauge II
Adama is offline   Reply With Quote
Old 03-06-2010, 08:09 PM   #8 (permalink)
View pyromaniacdave's Photo Gallery
Question
I have a 2005 corolla ce, this method works for all 9th gen corollas right??
pyromaniacdave is offline   Reply With Quote
Old 03-07-2010, 10:29 AM   #9 (permalink)
yes, it'll work for your car.
