Originally Posted by shadowtag88
anyways, immediately behind the alternator when facing the car straight on, i noticed a build up of residue from what looks like a fresh oil leak.
what is immediately behind the alternator? right under the plastic cover.
thanks
that sounds like the timing chain cover/front side of the valve cover area.
have you taken off the plastic cover to look for where the leak may be coming from?
Originally Posted by spinfisher
i'VE HAD THE SAME PROBLEM WITH MY '07. i NOTICE OIL LEAKING UNDER THE CAR , JUST A DROP OR TWO. i SAW A OIL BUILD U AT THE POWER STEERING PUMP. I THEN TOOK IT TO THE DEALER HE SAID THEY COULD NOT FIND ANYTHING , BROUGHT IT BACK 2 WEEKS LATER AND THE SAID IT WAS THE CAM CHAIN TENSIONER O RING . SAID THEY REPAIRED IT STILL LEAKS I GUESS I BEING GOING BACK AGAIN , OF COURSE THE WARRANTY ENDED IN FEB. SPIN
yea, really the only thing directly above the power steering pump is that chain tensioner. I noticed a small leak around it on my car too, not a huge issue though. It might be possible yours could be leaking from the valve cover or timing chain cover though, It's hard to say when I can't see it for myself, ya know.
SIU Auto, we don't mess around... much
—2005 Silver Streak LE (FINALLY 6speed swapped
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
