Vent gose sucking oil + low idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2010, 01:00 AM   #1 (permalink)
View 04rollaftw's Photo Gallery
My 04 rolla was idling low(like 600) so I tried to clean the idle speed cotroller thats localted under the throttle body. I accidentally stripped the screws. So I just sprayed throttle body cleaner into the 2 holes where the valves of the ISC are. Reused the throttle body gasket.
CEL came right on when I start the car. Codes were identical to those listed on TSB of intake manifold gasket. Good amount of smoke was coming out the exhaust. I went ahead and replaced both gaskets but the symptom did not go away.
My automotive tech teacher looked at the car and found the problem to be the front vent hose(not the PCV one) that goes on to the valve cover has a very strong suction and is sucking oil out of the crank case. Random misfire codes was caused by the oil on the spark plugs. We plugged the hose, cleaned the spark plugs and called it a day
Could I have messed up the ISC by spraying cleaner into the holes? I heard theres a rubber gasket that prevents liquid from getting into the electronic part and cleaner can dissolve that gasket.
Please
04rollaftw is offline   Reply With Quote
Old 02-28-2010, 05:30 PM   #2 (permalink)
View dorman68's Photo Gallery
Sounds like a bad or stuck pcv valve, I would check that first.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 02-28-2010, 07:59 PM   #3 (permalink)
I thought the same thing. Already replaced.Did not help the idle. The old one did not look that bad though it has lost some tension. Thx for the input anyway. Will check for vaccum leak with carb cleaner sometimes this week. I think I noticed some seesing noise just now when the car was idling with the hood open.
