My transmission fluid needs to be changed...Power Flush OK?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2010, 09:33 PM   #1 (permalink)
View empirefalls's Photo Gallery
It would be $120...Dealer said they would power flush $180
I need to change fluid asap. There are no issues with the tranny
but the fluid is dirty. I have read the Power Flush may not do
a good job, if true will it do some good for the time being? Will
it do any harm?
T-Tech Transmission Atf Exchange Unit
• Exchange virtually 100% of the vehicle's transmission fluid.
• Auto-alignment for fast and easy hookups.
• Auto-bypass mode when service is completed means the machine can be left unattended.
• Vehicle's own transmission regulates the exchange process guaranteeing that proper pressure and fill are maintained.
• Includes standard and special fittings.
• Leak-free, dry break quick connect couplers.
• On-board pump speeds cylinder filling.
• Drain pan feature to conveniently drain transmission pan.
• Features a rugged new roto-molded case design, upgraded internal plumbing connections, a drip tray for hoses to reduce ATF drips, enhanced storage space and side pocket for storage of manuals.
• Clear fluid cylinder drives home the benefit of ATF exchange.
http://www.autobarn.net/xxxw-ttctt40...te=google_base
empirefalls is offline   Reply With Quote
Old 03-05-2010, 08:53 AM   #2 (permalink)
GO KING'S GO!
dktaco's Avatar
View dktaco's Photo Gallery
Just buy the ATF 4 fluid from your dealer, drain, refill, drive around 10 mins, drain, refill, drive around another 10 mins, drain, refill = all done. $180 is way too much and those machines have a tendency to clog the filter, while draining and refilling dosen't. I also dropped my pan to clean it from crap inside and put on a new OEM gasket. The whole cost was about $65 for a case of ATF 4 and gasket.
dktaco is offline   Reply With Quote
Old 03-05-2010, 09:03 AM   #3 (permalink)
I am a tad confused. The Toyota dealer does it the flush way, i would think there are no side effects like clogging the filter if the dealer did it the power flush way.
I am not in a postion to do my own auto work right now.
Old 03-05-2010, 11:41 AM   #4 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
What are the miles on your car? My fluid is turning darker with use, but is still fine. I'll do a pan drain this summer just to keep it fresh, but a flush would be over kill for me. I think that many of the dealer recommended flushes are a money maker for the dealerships.
As an example, my truck was at the dealer for TSB. When I picked it up the tech had written on the ticket that my trans fluid was dark and smelled burnt. Recommed flush. Funny thing is that I did a pan drain every 25K miles... and had just done a pan drain 2 weekends prior. They never even looked at mine, just wanted the business. The service manager said his tech must have confused my (bright YELLOW) truck with some other truck that day. Riiiiiight.... Point I'm trying to make is to be careful with what a dealership tries to sell you. Their major concern is making money and do not always have your best interests in mind.
Maybe your car lives a harder life than most... but I'd think hard about getting a flush. Perhaps a indy mechanic will do a pan drain for you and save you some coin?
Good Luck,
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 03-05-2010, 08:26 PM   #5 (permalink)
80,000 miles,burnt tranny fluid..drove lots of hills,mountain size hills sometimes
