Originally Posted by rsirois
How many miles are on it?
Corolla's don't really need a tune up for about 100k, and a tune up is just plug replacement on modern cars.
Rear brakes are self adjusting. Unless there's a specific problem with the brakes, I wouldn't touch them.
Engine induction service - Sounds like a fuel injector cleaning. Not neccesary unless you have a problem, like rough running, or a misfire code of some sort on the engine.
the car just turned 100k... I see..so its just those basic maintenance stuff..
well the CEL came on b4 and I brought it to a parts store to check the code out...the reader said its a misfire on cylinder 1...and then the guy cleared the code...i've written the code on a piece of paper but i cant find it now...anyway, i did some research and one of the things that was a culprit was the MAF sensor...so I took it out and cleaned it...and the CEL did not come back...dunno if thats related.
so do u suggest that I let them clean the injectors or should I just buy one of those stuff u put in ur tank to clean the injectors? cuz i know i cant really clean the injectors at home..without a machine..
as for the brakes, its still in a good working condition so ill just leave it alone
thanks!
Originally Posted by dorman68
The "Rear Brake Clean and Adjust" is a bullsh*@ service. It's just a tactic to generate revenue. Every time I go to the dealer I am always offered this ridiculous service.
i see...well so far i think this is the only one that my mom got an offer to clean and adjust the brakes...and like what rsirois said above, "it is self adjusting" so that means i don't have to touch it until i need to replace the shoes...
