drivers side suspension problem, subframe loose? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2010, 02:43 AM   #1 (permalink)
View jeepwranglerg's Photo Gallery
Ok ive replaced many parts on car and still a pesky suspension issue going over bumps or uneven roads. I was thinking the sway bar could be issue like being bent. Roads in my area can have deep pot holes on freeway going fast. Then got to thinking how suspension is bolted together. If my subframe was loose moving around going over bumps could change whole alignment. Control arm in mounted to subframe what bolts can i check also do they use rubber or pucks to mount body. There is a pop knock when starting from dead stop on driver side.
Items ive replaced to date, ball joints,tie rod, inner tie rod,wheel bearing,strut,strut mount,cv axle,strut, control arms pretty much everything except coil,sway bar parts,hub. Gotta be subframe! Replacing these parts just to find problem is fine as they are worn out from boinggg right pull.
jeepwranglerg is offline   Reply With Quote
