To stay within the OEM tire size (overall diameter), so that you minimize speedometer errors. Stick with a 60-series tire, if you want to run up to a 205 width.
OEM is 185/65-15 or 195/65-15 depending on the trim level. A 205/60-15 tire would be around 1% error or so - less than the resolution of the speedo. Tire weight depends on manufacturing process - some tires are significantly heavier than others for a given size. Rolling resistance will also vary, depending on tire construction. Being wider, automatically will ding overall fuel economy - but the increase in traction and slightly shorter sidewall (less sidewall flex), IMO, more than makes up for the loss in fuel economy.
