rpm fluctuation in morning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2010, 03:02 AM   #1 (permalink)
View alexdcosta's Photo Gallery
I own a Corolla 2006 1.8 XLI. I have noticed that the RPM flucuates between 1700 and 1100 during first start in morning when the engine is cold. I dont push the gas pedal at all. I let the engine warm on its own. the temp outside is around 21 deg C. When the engine gets warmer after 5mts, then the RPM remains constant @ 1000.
Why is the random fluctuation happening @ first start ?
alexdcosta is offline   Reply With Quote
Old 03-21-2010, 11:03 AM   #2 (permalink)
View tarbasd's Photo Gallery
Most likely manifold gasket. Do a search, you will find tons of posts.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
Old 03-21-2010, 08:56 PM   #3 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $271875
View TrdSpeed140's Photo Gallery
possible leaking intake manifold gasket.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 03-22-2010, 10:06 AM   #4 (permalink)
View dorman68's Photo Gallery
I agree, a very common failure.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 03-22-2010, 04:00 PM   #5 (permalink)
mikered30's Avatar
Gameroom cash: $532067
Does your engine have an Idle air control valve and what engine do you have? Most of the idle hunting with a leaky manifold gasket happens when it is very cold, not warm like where you live. I am not entirely convinced it is a bad gasket yet, and it usually that trips a CEL. There is a TSB for this issue, but it is for US corollas. Has this happened since new? Spray carb cleaner around the intake manifold gasket when the engine is running and listen for a surge in RPM.
mikered30 is offline   Reply With Quote
Old 03-22-2010, 04:44 PM   #6 (permalink)
I'd also like to know how fast the RPMs are fluctuating. for instance, does the rpm go from 1100 to 1700 in a matter of a second or two? or is it even more gradual or is it faster than that?
