Hey all!
This is my first post in the forums. Glad to be here!
I've been silently following the discussions and decided to install a Weapon R Secret Weapon SRI in my 9th gen corolla.
Thanks to member PEWPEW for his brilliant post which helped me a lot.
Weapon R Secret Intake w/ 2009 Corolla S w/ PICS!
The instructions on paper were a bit confusing, especially the metal bracket:
Mounting at the bottom:
Does the U-shaped part go between the clamp and the hose? This is what I did, its just sitting there unsecured.
View from the bottom:
More questions:
I have two stray hoses and a part of the MAF which I don't know where to attach to the Weapon R SW SRI.
In Photo A:
You will see at No. 1, I plugged up the side inlet of the SRI pipe with tape for the moment.
I believe the pipe at No. 2 should fit into No. 1, but if I do that what happens to No 3.?
Also where should the pipe at Number 4 go?
For a better look at the Numbers 3 and 4, see Photo B
I don't know what this unit is for, it was attached to the stock air filter box near the MAF.
Could someone please advise?
Really stuck here.
