Old Old Motor Oil...will Kill The Engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2010, 01:12 PM   #1 (permalink)
View carioni's Photo Gallery
i am abou tot buy one 03 corolla.
guess what? when i went to try out the car, drove into gas station and asked for a lube service, oil change and filter replacement.,
the techie said "will not change your oil due to this (and showed me one sticky paste..later i found out that was about a long time no-oil change. )O
went ahead in investigate this black stuff inside the engine chamber..and it is cause by a very old oil inside the engina.
okay..the ownser put the corolla to service it, i watched the service, took pictures and everything.
now my question is, after flushed and de-carbonized valve chamber and carter...
is this a safe buy? or a no-go sign to me?
pictures:
WHAT DO YOU THINK? SAFE BUY? OR A NO GO?
carioni is offline   Reply With Quote
Old 03-30-2010, 08:16 PM   #2 (permalink)
View Murgatroy's Photo Gallery
Run, do not walk away.
Murgatroy is offline   Reply With Quote
Old 03-31-2010, 08:43 AM   #3 (permalink)
yeah, im outta this!. will wait for a clean serviced engine...not this crap
t-you
Old 08-13-2010, 04:35 PM   #4 (permalink)
View cswaite's Photo Gallery
There is no way in hell I would buy this car with the way that looks. Good thing it was noticed before you bought it, wow I wonder if the oil was ever changed.
cswaite is offline   Reply With Quote
Old 09-15-2010, 12:44 PM   #5 (permalink)
Marcin_CorollaLE's Avatar
View Marcin_CorollaLE's Photo Gallery
oh shit! poor Corolla
Marcin
2005 Corolla LE
Marcin_CorollaLE is offline   Reply With Quote
Old 09-15-2010, 01:43 PM   #6 (permalink)
Gameroom cash: $105620
View wylee's Photo Gallery
It looks like that car went for a swim AND went about 100k without an oil change.
2010 Corolla S 5 speed. It's GONE!
2007 Corolla CE Auto
2010 Aveo5 - good CHEAP car so far
wylee is offline   Reply With Quote
Old 09-15-2010, 08:08 PM   #7 (permalink)
View scarney1988's Photo Gallery
Hmmmm..... If you have not spent any money on that.... Do not spend any money on it. That sort of sludge build up can come from a few things. Most likely is not getting oil changes often enough, clogged PCV systems, and frequent overheating. In anycase, I would do as a previous poster recommended and run away. There has to be another corolla out there for you, cause that one is not worth buying.
Good luck....
If you do buy it... be prepared to do oil changes way more often than usual.
Honestly though... ide suspect that thing is about to let go with that much sludge inside
scarney1988 is offline   Reply With Quote
Old 09-16-2010, 06:54 AM   #8 (permalink)
View dorman68's Photo Gallery
X2 Run really fast!!!
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
