2003 Corolla steering wheel shakes and one hot front brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2010, 10:17 AM   #1 (permalink)
View Toy29's Photo Gallery
USA 2003 Corolla steering wheel shakes and one hot front brake
I have a 2003 Corolla S with 130,000 miles. Here recently the steering wheel started violently shaking between 50-70mph. While checking the tires I realized my right front brakes were much hotter than the left. I took the tires to get balanced and it seemed better during a follow-up drive. However, after a short time the shaking came back and at almost any speed above 30mph. It remains when I slow down and the brakes pulsate rather badly. I noticed the brakes did not pulsate when I initially left on this test drive. It seems to develop, which would seem to suggest possible caliper problems but not sure. The one thing I do know is that I could really feel and smell the right front brake after the drive, which included some highway and city driving, but only about 6 miles worth. I am not sure what the problem could be; whether there are two separate issues or one that is leading to both. Any help or guidance would be greatly appreciated.
Toy29 is offline   Reply With Quote
Old 04-07-2010, 10:48 AM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
could be a really badly warped rotor, seized slider pins, or even a stuck caliper piston. best to get it checked out by a pro if you don't feel confident doing it yourself.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 04-07-2010, 11:42 AM   #3 (permalink)
Thanks for the suggestion. I keep coming back to the rotor too. I am just confused as to why it seemed fine initially and then got worse. Could it just be warped and as the heat builds up the problem becomes more pronounced? I too do wonder about the slider pins. Think I need to get a whole new caliper? What would be your first guess?
Old 04-07-2010, 07:50 PM   #4 (permalink)
View AZrolla9's Photo Gallery
i'd try the rotor first, typically when you apply the brakes and your steering wheel shakes, its typically the rotors going. hope that helps.
AZrolla9 is offline   Reply With Quote
Old 04-07-2010, 08:28 PM   #5 (permalink)
View 03mooncorolla's Photo Gallery
Had a similar thing happen a few years ago.
Your pads have not been fully releasing after application, sliders will need cleaning, in my case I needed rotors and pads at 90,000kms got good life out of them anyway.
A hard application may free it up some if it's only sticking a bit, but the damage may have already been done.
03mooncorolla is offline   Reply With Quote
Old 04-07-2010, 10:58 PM   #6 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Your front disks have been completely warped, which is why your steering vibrates.
You will need to either get the front disks machined or if they cannot be machined then you will need to get both new disks and pads replaced.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 04-08-2010, 11:41 PM   #7 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
I think you should just replace the rotor and pad, since is 03, might as well change them plus those rotor and pad is not that expansive.
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 05-09-2010, 08:55 AM   #8 (permalink)
View mhinz000's Photo Gallery
i just ran into this on my 03 S, same exact issue, turns out the piston in the caliper decided to seize up so it wasnt releasing pressure off the rotor. when i took it off, i was able to push the piston back in but it was very difficult, ended up getting a new caliper. was like 46$ after the core was returned to autozone. hope this helps a little.
mhinz000 is offline   Reply With Quote
Old 05-12-2010, 11:01 AM   #9 (permalink)
View tarbasd's Photo Gallery
Just what the others said. Most likely scenario is that you caliper stuck, and the heat buildup warped the rotor.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
