Originally Posted by omgLIFT
I know a +35 offset isn't low but being on 17x8 and at stock height you won't rub. Once you lower your car I would hope you would be having your fenders rolled/pulled or else your going to be ruining your tires and fenders. You can run camber or a stretched tire to avoid having to pull your fenders but if I were you I would.
I'm planning to use either eibach/koni together or B&G suspension kit(springs and struts). I know eibach would only be an inch drop and b&g would be 1.6".
Still doing research regarding rim width and offset in particular. Trying to have an aggresive stance and better handling.
Thanks for all helpful inputs....
