If The Sound Is At Speed I would Assume It would Be Some Sort Of Rotating Assembly Or Piece Of Body Work When Air is passing through or by it.I would Jack The Car Up And Check the Wheel Bearings (front and rear),Grab the top and bottom of the tire while in the air and give it a wiggle to see of there is any play at all,there should be none,Turn the tires,rotate the while on the car to see if you can find any kind of slop..... I would also Go through and just wiggle bodywork,front bumper,airdam,grilles are notorious for making noise too,These cars are very well built for the most part.Hope this give you a starting point,this is where I would start at least.
There Is No Charge For Awesomeness ** Kung Fu Panda**
Phantom Grey 2008 Corolla S
