probable bad ECU - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 05:47 PM   #1 (permalink)
View 05corollapop's Photo Gallery
probable bad ECU
I am brand new to the Toyotanation, and my daughter has a 2005 corolla with around 120K miles on it. The engine recently died on her, restarted and then died again the next day. The trouble codes are PO452 and PO607.
My research so far tells me the engine control module is probably dead. Since she is over the 80,00 mile warranty, what are my options? I am trying to make this as painless ($$$) as possible for her.
I located the ECU and have a part number, but I am wondering if a new one has to be programmed, or can it be plugged in and used?
Thanks in advance to anyone that can help
05corollapop is offline   Reply With Quote
Old 04-14-2010, 07:01 PM   #2 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
yes, it would have to be programmed with the car's VIN and the immobilizer will have to be programmed too.
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 04-18-2010, 09:25 AM   #3 (permalink)
I installed the ECM yesterday - what type of unit is needed to program the VIN# and immobilizer? Is this a dealer only thing?
Thanks
Old 04-18-2010, 11:03 AM   #4 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Thanks
Dealer only, they should have asked for your VIN when you bought it, assuming you bought it new. Does your car work without the VIN being entered?
mikered30 is online now   Reply With Quote
Old 04-18-2010, 06:12 PM   #5 (permalink)
Yes, I bought the ECM new and the car runs fine, but the check engine light is on with trouble code P0630 (VIN # not programmed).
Old 04-19-2010, 09:43 AM   #6 (permalink)
rainking1978's Avatar
View rainking1978's Photo Gallery
How about the immobilizer? How did you get that to work?
2009 Honda Civic Si
2005 Corolla CE
2006 ZX10R
rainking1978 is offline   Reply With Quote
Old 04-20-2010, 06:42 AM   #7 (permalink)
View dorman68's Photo Gallery
My buddy needed a new ECU in his 06 Corolla. The local independant repair shop that diagnosed it and installed it said that they had to send the car to the dealer to program the immobilizer as there is not anything in the aftermarket available that can program the immobilizer.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
Old 04-20-2010, 08:34 AM   #8 (permalink)
What exactly does programming the immobilizer do? Will the car run OK until this can be done?
Old 04-20-2010, 02:26 PM   #9 (permalink)
the car should not be able to start without having the immobilizer programmed to the key and transponder
Old 04-20-2010, 04:12 PM   #10 (permalink)
It starts and runs fine - maybe it is because the VIN # has not been programmed into the new ECM yet - does this make sense?
