Amp damage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 07:00 PM   #1 (permalink)
View AZrolla9's Photo Gallery
Amp damage?
hey, so im currently running 2 12" subs and just recently got 2 10" subs, i have them wired up to the amp, im wondering about how long i can go with out doing any serious damage to the amp like overloading it. I plan on getting another amp and a distrbution block soon, i just wanna know my time tables
AZrolla9 is offline   Reply With Quote
Old 04-14-2010, 07:20 PM   #2 (permalink)
heartdisease's Avatar
Gameroom cash: $114370
View heartdisease's Photo Gallery
More info is needed but I would say if you aren't running it at a load it isn't rated at and the fuses aren't blowing you should be fine. Good airflow really helps, heat kills electronics.
heartdisease is online now   Reply With Quote
Old 04-15-2010, 07:26 AM   #3 (permalink)
dmryle's Avatar
View dmryle's Photo Gallery
need info. how many watts is the amp, whats the rms for the subs, how many channel is the amp, how hard are you running it? if youre pushing too much youre stretching the coil in the sub which will cause it to eventually blow
2003 Toyota Corolla S
dmryle is offline   Reply With Quote
Old 04-15-2010, 12:27 PM   #4 (permalink)
The amp is rated 650 watts, the 2 12" are 1200 watts max and the 2 10" are a small 300 watts.
thanks again
Old 04-15-2010, 01:03 PM   #5 (permalink)
How do you have your subs wired. What ohm load is the amp seeing? Running an amp that is rated at 2ohms at a 1ohm load is what I was talking about.
