4th Wheel Hub Bearing (HELP!)
I am a new member and not as familiar as some of you with the Toyota make. I have owned my Corolla for roughly a year and a half now.
The front wheel bearing began to go out around October of last year. I decided to buy a cheap bearing from O'Reilly's and replace. After a few weeks the bearing began making noise. Tried this 3 consecutive times, believing that maybe it was a cheap bearing. On my fourth try, I bought a higher quality Federal Mogul bearing and gave it a try. After two weeks the bearing began making noise again. I am not sure why this keeps happening. Whether there is an issue with the wheel hub assembly as a whole or just bad bearings but I cannot afford to continue doing this.
I was wondering if anybody had a similar experience or some advice as to whether I should just by a whole new wheel hub or maybe there is another existing issue that is factoring into my situation. I did most of the work except for pressing on the bearing. My uncle, who happens to be a mechanic did that part. Any suggestions into my situation would be greatly appreciated.
