Hot front hub and brake rotor on one side. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-20-2010, 06:47 PM   #1 (permalink)
View maina_nh's Photo Gallery
Hello, new to the forum. I have a 2003 Corolla S that my wife noticed a smell on today. When she got home I noticed the driver side hub was pretty hot. Much hotter than any of the others. The rotor on that side was also hotter then the passenger side. Does this seem like a hub issue or a stuck caliper issue? Would stuck calipers make the hub get a lot warmer than the other side? Thanks for any help.
maina_nh is offline   Reply With Quote
Old 04-20-2010, 07:01 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Sounds like a stuck caliper. You will have to check and then probably replace the caliper, pads on both sides, and rotor and then bleed the brake fluid.
mikered30 is online now   Reply With Quote
Old 04-20-2010, 07:05 PM   #3 (permalink)
I can't just get the calipers adjusted or something?
Old 04-20-2010, 07:17 PM   #4 (permalink)
mikered30's Avatar
It could be the piston or the bolts. You will have to inspect it.
Old 05-09-2010, 08:53 AM   #5 (permalink)
View mhinz000's Photo Gallery
i just had this similar issue arise with my 03 S, it ended up being a stuck piston and ended up buying a new caliper. only 45$ after the core was returned to autozone so not bad but still annoying.
mhinz000 is offline   Reply With Quote
The Following User Says Thank You to mhinz000 For This Useful Post:
maina_nh (05-09-2010)
Old 05-09-2010, 10:50 AM   #6 (permalink)
I was going to replace the caliper but then I realized that if I pump the brakes a few times before I start out AND then press then down fairly hard at the end of the driveway, while I am moving, that the brakes are fine after that, i.e. they don't get hot. I had someone check the pads and there is a fair amount of life left on them so I am going to keep doing this. I think the calipers got alittle rusty.
Old 05-12-2010, 10:58 AM   #7 (permalink)
View tarbasd's Photo Gallery
At least you should clean the calipers. I would be worried that the technique will stop working on the day you drive a few hundred miles, and then you will have to replace the whole assembly.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
