Has your mechanic tried to diagnose the cause of the problem or did he just check the manifold for leaks at your request? He should be able to easily test the response rate of the sensor to determine if you got a faulty one. As far as ECM updating, any reputable shop should have the equipment to do that these days through a j2534 passthrough device. It basically takes the updated info from the dealer database and flashes it to your ECU. As far as the possibility of a manifod gasket leak, you might want to check it when the engine is cold. If the leak is very minor then it may actually go away as the engine warms up and the rubber seal expands.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
