2006 Corolla, P0138 Malfunction - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2010, 03:47 PM   #1 (permalink)
View tonychang's Photo Gallery
Canada 2006 Corolla, P0138 Malfunction
Hello all,
Just recently purchased a 2006 Corolla via used dealership in Burlington, Ontario, Canada. I have had the vehicle for approximately 1 week. The car runs fine there does not seem to be any issues, it came off of a lease from a Toyota Dealership and sold at an auction where the used dealer purchases from.
The vehicle has 73,000km on it.
VIN: 2T1BR32E96C639145
After approximately one week of flawless driving I noticed that the check engine light had come on. I read the manual and took all procedures to narrow down the problem. I was unable to successfully figure out what was wrong so I took the car back to the used dealership where I purchased the vehicle. He hooked up his tester and the error code "P0138" appeared.
His solution was to reset the code so that it would no longer show up. He told me that if it shows up again, to bring it back to diagnose the problem again. After reading and doing my research thanks to this wonderful forum I have noticed that there seems to be a lot of problems with the 2005-2007 range of Toyota's and the ECM's. Should I be worried about this? Could my vehicle be showing signs of similar problems that are linked to the ECM problems on these forums?
So let's say that the P0138 error message comes up again... is this something that is covered by warranty? If so, which warranty category would this fall under (powertrain, emissions, major emissions).... any input would be GREATLY appreciated.
Thanks.
tonychang is offline   Reply With Quote
Old 05-03-2010, 07:50 PM   #2 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada
Originally Posted by tonychang View Post
Hello all,
Thanks.
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
looks like is your o2Sensor not the ECM
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 05-03-2010, 08:40 PM   #3 (permalink)
Thanks so much for your reply... How major of an issue is this? Is it dangerous to drive with this problem?
Is this covered by warranty? If so which warranty category does this fall under? Also how easy is this to fix, and if it's not covered by warranty I definitely will not be taking it the Toyota dealership since I do not want to get ripped off.
Old 05-03-2010, 09:46 PM   #4 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
I don't really think o2 sensor is under warranty at your mileage, but sometimes just need to clean it that is all to fix the obd code. but you can always change a new one, I think Napa sells them maybe around $70 +/-
Bank 1 = at the engine (usually in the exhaust manifold)
Bank 2 = down stream of the catalytic converter
you can also find how to clean o2 sensor in this
http://www.ehow.com/how_4809599_clean-o-sensor.html
Comprehensive Coverage - 3 years or 60,000 km
This warranty includes 24 hour Roadside Assistance and other benefits, as well as
coverage of repairs on any part of the vehicle that is defective in material or
workmanship under normal use and maintenance. Different warranties apply
to original tires.
Powertrain Components - 5 years or 100,000 km
This warranty covers repairs to powertrain components that are defective in material
or workmanship under normal use and maintenance.
Major Emission Control Components - 8 years or 130,000 km
This warranty covers repairs to specified major emission components that are
defective in material or workmanship under normal use and maintenance.
Corrosion Perforation - 5 years unlimited distance
Any sheet metal found, under normal use, to have developed a perforation from
corrosion due to defects in material or workmanship.
Springs
Old 05-03-2010, 10:00 PM   #5 (permalink)
Thanks a lot for your reply. I think I will replace it if it's that cheap. Only if the error pops up again, if not then looks like I am good.
Old 05-03-2010, 10:01 PM   #6 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
You are welcome! Xie Xie
Springs
Old 05-04-2010, 09:05 PM   #7 (permalink)
View jeff1000's Photo Gallery
There's a TSB for this CEL.
http://www.toyotapart.com/M.I.L._ON_...T-EG043-07.pdf
The TSB is for the US but it may apply to Canada.
Go to the stealership with your VIN and ask the service department for the maintenance records for your car. They shouldn't charge you for this.
The A/F sensor and the oxygen sensor should be checked before replacing any parts.
The TSB reports something like this:
check A/F sensor - OK
check Oxygen sensor - OK
If both are OK then replace ECM
To check the sensors you need a scan tool and/or multimeter.
jeff1000 is offline   Reply With Quote
Old 08-14-2010, 12:56 PM   #8 (permalink)
View kukuyi's Photo Gallery
did you fix your 2006 corolla problem finally?
kukuyi is offline   Reply With Quote
Old 08-14-2010, 12:57 PM   #9 (permalink)
p0138
did you fix your 2006 corolla problem finally? p0138?
Old 09-24-2011, 06:09 PM   #10 (permalink)
View AJ0319's Photo Gallery
hey i am having the same issue. was wondering where the o2 sensor is located so i can change it out before i change the ECM. thanks for you help
AJ0319 is offline   Reply With Quote
