fast idle on first start up
hi all
first off thank you for helping me with my brakes earlier it's great now. i own a 2007 corolla le about 39000 miles. i have another problem i think, i cleaned out my throttle plate and and throttle hose today. my engine was idling at about 600 to 750 rpms and rough now it's at 950 to 1000 it's a smooth idle, what's the problem is at the first start after sitting for a while i start it and the rpms go up to 2000 to 2100 and it slowly goes down to 1500 and then 1000 ,900 is this normal. also after sitting at a red light when i let go of the brakes the car moves it doesn't pull me at rhe red light though .the shop also told me there is a pending code in the ECU for a coolant temperature sensor but no check engine light is on at all and never went on . the car doesn't hesistate or stall . they also disconnected the battery i read on corolla nation that the computer has to relearn to idle is there a problem or is it normal should i have toyota reset the ECU oh toyota didn't do the work.it's only been one day should i wait? thank you for any help!!
