2003 s third brake light problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2010, 05:33 PM   #1 (permalink)
View Hubcap's Photo Gallery
Hello all,i just bought a '03 corolla s,and noticed the 3rd brake light doesn't work.i changed the bulb,and nothing.My car did not come with a owners manual,so i am not real sure if there is a fuse for it..Any help would be appreciated.
Thanks,james
Hubcap is offline   Reply With Quote
Old 05-13-2010, 08:39 PM   #2 (permalink)
i checked th fuses under the dash..nothing.
Old 05-17-2010, 01:29 PM   #3 (permalink)
View qwho's Photo Gallery
In the S model, the third brake light is in the spoiler.
In my S, there is nothing in the place where there would be a brake light in other models, there is no bulb or a place for a bulb.
qwho is offline   Reply With Quote
Old 05-17-2010, 02:09 PM   #4 (permalink)
Well,apparently my car is a cobbled up pile.Alot of problems with this car.It doesn't have a spoiler...I took the back deck loose and traced the wireing,and found where the wires were disconnected..plugged it up and it works..Then i took the rear pillar covers loose and discovered that the rear defogger was also unplugged.Fixed that.
Now since i got it home:
the check engine light is on
the cruise stopped working
the a/c doesnt blow cold at idle
the car will not shift out of park with out pushing the bypass button.
What a mess.
Thanks for your response though!
Old 05-19-2010, 10:03 AM   #5 (permalink)
View tarbasd's Photo Gallery
Good job!
What a mess.
Call me crazy, but I bet that these are related, and they also may be related to the wiring. There is some issue with the way the car is sensing braking. The cruise doesn't work, because the computer thinks you are pressing on the brake. It will not shift out of park, because then it thinks you are NOT pressing on the brake. The check engine light is on, because... maybe there is a short in the wiring that you plugged in. Maybe the previous owner disconnected it on purpose for this very reason.
OK, the A/C is probably unrelated, and it may be due to low refrigerant level.
'05 Corolla S, 4 cyl 1ZZ-FE (90000 miles)
tarbasd is offline   Reply With Quote
