AC not working great - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2010, 12:23 PM   #1 (permalink)
Woodyg's Avatar
Gameroom cash: $138765
View Woodyg's Photo Gallery
As the title says my AC is not working great. The wife saw a big puddle under it today. I think it was just water and that is probably OK, but it is not super cold. I have a recharge kit for a 134A. before I charge head first into I was looking for any feedback. is 134a the recommended stuff? is there any special technique to know when it is full? should I add the oil stuff? should i add a dye? I have had the car 9 months I do not know the history of if it has ever been recharged. it has 128k on it now. thanks for any feedback.
2006 Vibe, White, 1zzfe, auto ( Toyota type IV), AWD, PW, PL, CC, AC, 161,000(5/12/2012)
1998 Camry LE, 4 door, Puke Green, I4(5S-FE), CA Emissions, Auto(A140E), 122k(3/22/2012), AC,CC, ABS, Built in Japan 04/98. Grandmas old car(acquired 7/22/2011), work= precat Denso A/F sensor, NGK wires.
Woodyg is offline   Reply With Quote
Old 05-25-2010, 08:19 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Puddle under the car is normal when the AC is running, assuming it is water. Recharge kits are ok, but generally most people over charge their systems and get mad when it blows warm air again. There are videos on youtube on how to add 134a. It is fairly easy to do. If you do decide to do it, only use a recharge kit that has a low side gauge on it. If the kit does not have a gauge, dont use it or get another one. 25-40 psi on the low side is the pressure you want in the corolla. You can take it to the dealer and have them test it for $80 or so or chain replace places do it too. Might want to gently rinse the condenser first and change the cabin air filter if it was not look at for a while. Also check the condenser for damage/holes. Only add dye if you suspect a leak and have a leak detector machine. You likely do not need to add oil. The best way to get it serviced is to take it to a professional. If there is any moisture in the system, they can evacuate it, pressurize it, and look for leaks. Just adding 134a to the system will not help if there is moisture in the system.
mikered30 is online now   Reply With Quote
Old 05-25-2010, 08:41 PM   #3 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
When was your cabin air filter last changed?
If it's old or even more than a little bit dirty it impedes airflow enough for the AC to not function properly.
Even the difference between a brand new filter and no filter with the AC is incredible.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 05-26-2010, 09:35 AM   #4 (permalink)
Woodyg's Avatar
I have a vibe/matrix( built on a corolla). I pulled the cabin filter a month ago it was nasty. I have not replaced yet. I did not rinse off the condenser but it looked clean. I put a gauge on the low side of the system. I put the ac on max with the doors open. the pressure was about 39 with the compresssor off. when the comp kicked on the pressure went down to 34. It was 90 degrees out. I was reading that when it is 90 outside the pressure should be beteween 45-50. does this sound correct? I also dont know if I use the pressure when the compressor is on or off.... I am going to get a thermometer also.....thanks
Old 05-26-2010, 10:57 AM   #5 (permalink)
mikered30's Avatar
Replace the filter will help and gently rinsing the condenser of stuff will help too. Some people insulate the low side ac line, it helps a bit but not much. Check the pressure of the low line with ac on max and on recirculate. When you get the digital thermometer stick it in he center vent with ac on max, recurlate, and at 2000 rpm. Temp should be between 39-45 degrees.
the pressure should be at what I wrote earlier.
Old 05-26-2010, 05:45 PM   #6 (permalink)
Woodyg's Avatar
Mike and Gideon thanks for your help. I bought an AC thermometer today at advance auto. I put the car on max blower at 2/3 speed , revved the motor to 2k rpm within about 10 seconds the t-meter was reading about 42 it has a green dot on it between about 38-42 it was at the top of the dot. I went between recirculating and not recirculating, it did not change. it was 90 degrees outside. I think I will leave it as it is for now. I am thrilled because the wife would have hounded me all summer that the ac was not working......thanks again.
