Switching coolant types - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2010, 08:53 PM   #1 (permalink)
juicedz's Avatar
View juicedz's Photo Gallery
Can I switch over to the 05+ radiator coolant to reduce the intervals between flushes? 05+ is red where 03-04 is pink correct? thx
Got a couple thousand miles to go until I do oil, coolant, trans fluid/filter.
2003 Toyota Corolla S
juicedz is offline   Reply With Quote
Old 05-28-2010, 10:09 PM   #2 (permalink)
on full afterburner
Gameroom cash: $1346597
Sure can.
Just make sure you do a thorough flush to remove all the old coolant before switching over.
Old 05-29-2010, 02:53 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Pink is the new formula and red is the old formula. The pink coolant can only be purchased as a 50/50 diluted coolant -- it's half deionized water. The red coolant can only be purchased undiluted.
I have no idea how you are going to get the pink stuff up to 50/50 though since you can't drain all the water out of your cooling system.
You could probably use something like Peak Global if you want to extend the interval.
2007 Camry 2.4L 5M
Old 05-29-2010, 05:33 PM   #4 (permalink)
juicedz's Avatar
Would I be better off purchasing the radiator coolant from the dealership and then taking it to a shop to have it flushed with a pressurized system?
