Stiffen up suspension help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2010, 11:13 AM   #1 (permalink)
View mhinz000's Photo Gallery
hi there, tried doing a little searching on stiffening up the suspension but couldnt find the answer i was looking for. i have an 03 corolla s and it just feels way too spongy and was looking to stiffen the suspension up all around and maybe lower it an inch. seems like when i have someone in the back seat the ass sags too much for my liking. if you have any suggestions it would help me out a bunch.
Also im trying to get a hold of some push clips that hold the plastic fairings on under the motor preferably be able to order them online if possible as i am located on a military post in germany. Checked 1sttoyotaparts.com but couldnt seem to find them if they even are available.
thanks
mhinz000 is offline   Reply With Quote
Old 06-02-2010, 12:50 PM   #2 (permalink)
View moggi1964's Photo Gallery
Eibach Pro springs will give you a little over 1" drop and a new set of OEM shocks (KYB I think) will feel a lot better assuming the ones you have are original and the car has done typical mileage.
Tokico Blues would be a good upgrade in the shocks department.
Both items are available online.
moggi1964 is offline   Reply With Quote
Old 06-03-2010, 12:36 PM   #3 (permalink)
An Auto Tech Student
TrdSpeed140's Avatar
Gameroom cash: $272375
View TrdSpeed140's Photo Gallery
also look into a rear sway bar, Progress makes a nice 24mm one that you can find around for a good price and they help stiffen up the rear end nicely when turning, it's, imo, a really good bang-for-your-buck part.
http://www.monkeywrenchracing.com/pr...oducts_id=1205
that's where I got mine from, they're a trusted source among us ZZ motor enthusiasts and they have it for a really good price
SIU Auto, we don't mess around... much
2005 Silver Streak LE (FINALLY 6speed swapped)
[Injen] [JP Performance] [Vibrant Performance] [Protege Garage] [Power Enterprise] [NRG] [Eibach] [Progress] [Energy Suspension] [Speed Source]
TrdSpeed140 is offline   Reply With Quote
Old 06-03-2010, 12:58 PM   #4 (permalink)
kickin, thanks a bunch i will def take a deeper look into it. do you think with a 1inch drop with the eibach springs will affect 17inch wheels with a 45 series tire? i wouldnt think so but thought i would ask
Old 06-03-2010, 02:23 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1346597
Also look into getting stiffer struts.
Bilstein HD's have had some good reviews.
Old 06-03-2010, 04:57 PM   #6 (permalink)
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
More than suspension stiffness, you should look to increase the chassis rigidity as the 1ZZ chassis flexes way too much (used to have a 2004 Corolla S). Sway bars, strut tower bar can be a good start for this. If you want to spend more, you can buy the standard XRS fixed rear bench and 4-point chassis X-brace, which will help enormously to stiffen up the rear box.
p.s. Remember a stiffer suspension does not always means a better handling car. You could be understeering a lot more with a stiffer suspension, if not done right. However, a stiffer chassis will always lead to improved cornering speeds and stability (at the cost of comfort since any bump will ripple across the entire chassis) due to reduced chassis flex caused by inertia.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 06-04-2010, 09:03 AM   #7 (permalink)
the x-brace is off of the xrs or its an aftermarket piece?
Old 06-04-2010, 04:10 PM   #8 (permalink)
on full afterburner
Both are available. OEM and aftermarket.
