Rims - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2010, 11:23 AM   #1 (permalink)
View chrisanthony14's Photo Gallery
Rims
Hi guys
I need help finding a set of rims for my 05 corolla. Would this be a good candidate and do you think it well fit with out having and hub adapters and such?
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ209651986
Also what is the hub size for the 05 corolla?
Thanks,
Chris
chrisanthony14 is offline   Reply With Quote
Old 06-06-2010, 09:53 PM   #2 (permalink)
View moggi1964's Photo Gallery
5x100 with a central bore of 54.1mm.
You can get hub-centric adapters made if the hub on the new wheel is larger.
I couldn't see a set of wheels on your link.
Tirerack and 1010tires will supply the correct adapter for your application.
I bought some wheels direct from BBS and had a local machine company make the adapters. I run 16x7.5.
If you go with a wider wheel or a drastically different offset don't forget to get extended lug nuts and remember aftermarket wheels almost always need a different type of lug not than the OEM one. Usually these will be supplied if you buy from a wheel dealer.
Good luck.
Moggi
Corolla 2005S with Eibach Pro springs; Tokoco D-Spec shocks; TRD front strut and rear sway bars.
moggi1964 is offline   Reply With Quote
Old 06-08-2010, 06:09 PM   #3 (permalink)
Thanks for the tips moggi1964..i'll check that out pronto..
and i think the wheels has been sold.. so i missed out ahaha
