Brake squeak only during the first time braking. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 12:06 PM   #1 (permalink)
View Wildpenguin's Photo Gallery
I have a 2003 LE with 70k miles and my brakes only squeak during the first braking after starting the car. They stop squeaking after the first couple of brakings. If I park my car for a few hours and go back out again, the brakes still squeak during the first braking. I had the pads and rotors done 20k ago (roughtly 2 years ago). I spoke to the Toyota Dealership mechanic and he said the pads usually last around 30-40k miles.
Does anyone else have this problem or have any ideas on what this might be?
Thanks!
Wildpenguin is offline   Reply With Quote
Old 06-10-2010, 03:53 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
It is normal.
mikered30 is online now   Reply With Quote
The Following User Says Thank You to mikered30 For This Useful Post:
Wildpenguin (06-18-2010)
Old 06-11-2010, 01:18 AM   #3 (permalink)
View aceshi21's Photo Gallery
if it drives you crazy enough, do what i did, get some brake quiet (red) take out the pads, put the quiet on the back of the pads, let it dry for 20 minutes, reinstall, and then give it another shot. the brakes should not make any more noise.
brake squeak or squeal is caused by the pad vibrating between the rotor and caliper. the sound you hear is an acoustical result of this vibration. the brake quiet ads a layer to deaden the vibrations.
aceshi21 is offline   Reply With Quote
The Following User Says Thank You to aceshi21 For This Useful Post:
Old 06-11-2010, 06:49 AM   #4 (permalink)
baberz's Avatar
View baberz's Photo Gallery
it's probably break dust.
I have brand new breaks on my 06 rolla S and they still squeak.
If I break on them JUST right then they don't, but I'm gonna say break dust.
Women need a motive to have sex. Men just need a place.
Be careful of the toes you step on today
They just might be connected to the ass you kiss tomorrow.
baberz is offline   Reply With Quote
The Following User Says Thank You to baberz For This Useful Post:
Old 06-11-2010, 03:31 PM   #5 (permalink)
dust is going to be there regardless. it has little if no bearing on squeaking.
you more than likely have semi-metallic pads, which is the most common pad for normal driving. this along with the harmonic distortion mentioned above causes brakes to "squeak".
take 2 hours, and put the brake quiet on the back of the pads and your problem will be solved.
Old 06-18-2010, 07:32 AM   #6 (permalink)
Thanks for the responses! It's actually squeaking less now.
