In-dash cubby door very loose - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2010, 11:13 PM   #1 (permalink)
View flash4o's Photo Gallery
Kind of a weird problem – in my ’04, right under the clock there are two in-dash cubby areas – like for your cell or sunglasses.
The bottom one, with the flip-down door, got very loose all of the sudden. So much so that when I accelerate hard, that little door flops down.
Anyone else had this? Any ideas how to fix? I don’t want this thing flopping down every time I hit the gas…
Thanks!
flash4o is offline   Reply With Quote
Old 06-12-2010, 12:38 AM   #2 (permalink)
View dgleason's Photo Gallery
Did the tabs holding the door on break off? if not it sounds like the springs have come off. there are 2, one on each side. you have to pull out the whole assembly and find and reinstall the springs to fix it.
dgleason is offline   Reply With Quote
The Following User Says Thank You to dgleason For This Useful Post:
flash4o (06-12-2010)
Old 06-12-2010, 09:44 AM   #3 (permalink)
how does that assembly come out?
Old 06-12-2010, 11:46 PM   #4 (permalink)
The piece that the lighter is in just pops up, unplug the lighter wires. this gives access to two screws. unscrew these and the two bolts in the bottom of the center console. lift the console up and back you will have to unplug the accessory plug in the console. it will be in the vicinity of the two screws. remove the console then remove the center dial, fan control, on the center piece. under it there is a screw remove it. with a little coaxing the center piece comes straight out. the two springs are v shaped. I dropped one and lost it under the carpet. good luck.
flash4o (06-13-2010)
Old 06-14-2010, 12:22 PM   #5 (permalink)
boopie's Avatar
View boopie's Photo Gallery
I ended up just removing the whole door. I broke the piece off that the spring attaches to so i just took the door off. I think its better off without it anyways, since it where my ipod goes now.
boopie is offline   Reply With Quote
Old 06-18-2010, 07:36 PM   #6 (permalink)
View gearhead526's Photo Gallery
That happened to me, i ended up cutting some velcro and attaching it so it would latch, its lasted for sometime for me.
gearhead526 is offline   Reply With Quote
