Originally Posted by FinalGear
lol...if your lucky, heck...pray that your Corolla's gauge don't light up and don't get a crap load of codes....
ah..crap..what is Bung welded angle degree?
My 2 cents... If you wanted to do this mod.
Lets take a cheap off E-bay, OBX for example.
Cheap header, with no O2 sensor bung. Flows better than stock.
A good exhaust shop should be able to weld in a Bung. (Close to wear the stock one went. Double check location & O2 to firewall clearance)
Use a new O2 sensor. Leave your old one in the OEM manifold, there usually in there good, as well as new header, why would you use an old O2 ? I'd go go for the stock style O2, clips into the wiring harness. (saves cutting & splicing wires, especially if you want to go back to stock)
Heat wrap the header for best results. (Cuts down on underhood temps)
Should read as normal as stock manifold if your car is running correctly.
