The freon pressure is good, the relay is working, the pressure switch is working. I have checked and double checked all these things.
The clutch is a simple matter. It has a hot and a ground. When the hot wire is activated, it kicks in the electro magnet and engages the clutch. The signal is getting there, I've checked. Just to make sure, i unplugged the clutch and ran a ground into the plug on the ground side and a hot wire from the hot side to the positive batttery terminal. This should cause the clutch to kick and turn when the car is running. It did not, hence I think the clutch is bad.
