Where is the AC Low Port value on a 2005 ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2010, 08:40 AM   #1 (permalink)
View empirefalls's Photo Gallery
i dont think my AC needs to be recharged but i would like to check it anyways
i have done AC recharges before, i recommend not doing it alone for the first time.
the first time i did it, i disconnected the can before it was completely empty----the
can froze on my hands, the can sprayed green stuff all around, the can wanted to
launch itself into space--ALL AT THE SAME TIME.
empirefalls is offline   Reply With Quote
Old 06-24-2010, 12:18 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
The low side is the line that is very cold when the AC has been running for a while. It is on the left side. The high and low side have different valve fittings, so if you try to check the high side pressure with a low side fitting, it wont work, it is almost fool proof.
mikered30 is online now   Reply With Quote
Old 06-24-2010, 06:03 PM   #3 (permalink)
thanks mikered30
Looking down from the front of the car,where about is the low value, is it near the firewall,to the right or left of the engine?? near the battery....or is it buried near the bottom so i would have to bend down and get underneath of the car to get to it.
Old 06-24-2010, 08:21 PM   #4 (permalink)
mikered30's Avatar
To the left, near the power steering fluid at the top, it will have a black plastic cap on it, but so will the high line. The line will be cold with the ac running and probably sweating. Make sure you get a can of refrigerant that comes with a gauge on it. The refrigerant will only fit the low line, so no worries with trying to get it on the high line by mistake. 25-40 psi on the low side, not higher.
