Maintenance Light on Dash - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2010, 08:27 PM   #1 (permalink)
Best Car I Ever Bought
Exitium's Avatar
View Exitium's Photo Gallery
I just turned 30k on my 07 and the maintenance light did not come on I thought it was supposed to come on programed at maintenance intervals does anyone know?
Thanks
Exitium is offline   Reply With Quote
Old 06-30-2010, 09:05 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Flashes ever 4.5K miles and steady at 5K miles. Who changes your oil? They must do the reset.
mikered30 is online now   Reply With Quote
Old 10-15-2010, 07:03 AM   #3 (permalink)
View NorthGaYota's Photo Gallery
how do you turn it off???
04 Sienna XLE Limited
NorthGaYota is offline   Reply With Quote
Old 10-15-2010, 09:17 AM   #4 (permalink)
Gameroom cash: $172005
View bennor's Photo Gallery
The manual has the correct procedure to reset the maintenance light. Elsewhere in this site a poster indicated the following to reset the maintenance light: "with the car key on ACC, set your odometer on mileage(not trip a or b) then turn key off. then hold they button that switchs from odo and trip, then turn the key back to acc. while you are holding it down you will notice the maintenance light blink and go out. and then you are done. now that wasn't hard now was it."
bennor is offline   Reply With Quote
The Following User Says Thank You to bennor For This Useful Post:
NorthGaYota (10-15-2010)
Old 10-15-2010, 12:57 PM   #5 (permalink)
I don't have my manual..but I tries this today and it did not work. when key is at ACC the odometer doesn't show...did it anyway and did not work. put the key to on position and same thing.
Old 10-15-2010, 01:10 PM   #6 (permalink)
Looks like the previous link I posted may have been slightly off on the steps. According to this one, http://www.ehow.com/how_6491945_clea...a-corolla.html, here are the steps to reset the light.
  1. Turn your ignition on to view the odometer. Press your "Trip" stem until the display shows "Odo," instead of "Trip A" or "Trip B."
  2. Turn the ignition off. Press and hold the "Trip" stem. Turn the ignition back on, while continuing to hold the "Trip" stem.
  3. Wait until the odometer shows "000000." This lets you know that the maintenance light is reset. Release the "Trip" stem and remove the key.
Edit to Add: If the light doesn't go out after the reset its possible that something else is tripping the maintenance light.
GREENPUS (09-17-2011)
Old 10-16-2010, 10:40 AM   #7 (permalink)
that worked- thanks!
