No Start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-03-2010, 12:47 PM   #1 (permalink)
View cfrepro's Photo Gallery
No Start
I bought an 05 four months ago with miles in the mid 50's. I have had no issues with it until yesterday.
My wife was driving it and it suddenly started to run rough and die. It restarted and ran poorly for a few minutes and she was able to pull into a parking lot . . . not to restart again.
We pulled the fuel line and it was dry. The we checked for power at the pump. Only one wire had power and it was the fuel guage. We swapped the relays under the hood and nothing changed.
After searching I found hundreds of posts regarding hard start situations on the 05 Vibe/Matrix/Corrolla. They were hard to restart after sitting for an hour or so and involved tsb's on the pcm and the fuel pump.
It appears my situation may be different. Many people complained that replacing the pcm and or fuel pump didn't fix the problem. I never saw any definitive posts that stated posts that the problem was solved.
I am out of warranty and can't afford to start parts changing. Where do I go from here??
Rick
cfrepro is offline   Reply With Quote
Old 08-05-2010, 01:36 PM   #2 (permalink)
View Bentworth's Photo Gallery
Did you ever get an answer? I have the same issue with an 05 Matrix. _Dave
Bentworth is offline   Reply With Quote
Old 08-06-2010, 06:42 AM   #3 (permalink)
View dorman68's Photo Gallery
I would check all of your fuses under the hood and inside. Sometimes the EFI or ECM fuse (I'm not sure what it's called) pops because of a short in one of the oxygen sensors. Just my thought, hope this helps.
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
