need help with wiring on '05 corolla!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2010, 02:18 PM   #1 (permalink)
View hirothefungi's Photo Gallery
USA need help with wiring on '05 corolla!!
Hi-
I own a '05 corolla that has a short circuit somewhere but I can't figure out quite where it is.
Every time that I turn ignition to ON position, 15A AM2 gets blown...
Here's summary of what I did to try identifying the short circuit:
1) removed IL connector from Instrument Panel J/B and turned ignition to ON
-> AM2 does NOT get blown
2) reconnected IL, unpluged: a) IC, b) IK, c) IG, d) ID, e) II1, f) A12-14 on Airbag Sensor Assay, and g) C/OPN Relay ALL at the same time
-> AM2 got blown
3) ran ground-to-terminal resistance checks on terminals on CONNECTOR side of IL (female? NOT the ones on junction board)
-> terminals 3, 9, and 10 gave me infinite resistance readings
-> terminal 6 gave me resistance reading of only less than 10 ohms
-> other terminals gave me readings in range of 10K-2M ohms
So, here are the questions I have.
i) How can I disconnect connector II on Instrument Panel J/B?
ii) Where does the terminal 6 of IL on CONNECTOR side lead to?
(I tried to look it up in wiring diagram, but all that I found was that within J/B, it is connected to C/OPN relay... I don't think this is a ground...)
According to the wiring diagram (from negative end): IG -> terminal 2 of C/OPN -> terminal 1 of C/OPN -> branches to terminal 5 & 6 of IL, 8 of IK, 8 of II, and 12 of IC
iii) WHERE IS THE SHORT CIRCUIT??!!
thank you guys soooo much in advance for taking your time to read this and giving a thought into it!!
hirothefungi is offline   Reply With Quote
Old 07-04-2010, 08:48 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
http://www.eserviceinfo.com/download...A_COROLLA.html
The download on there has the wiring manual and will help you with finding the problem.
mikered30 is online now   Reply With Quote
The Following User Says Thank You to mikered30 For This Useful Post:
hirothefungi (07-05-2010)
Old 07-05-2010, 10:29 AM   #3 (permalink)
Thanks for the post.
I've looked through the wiring diagram that you posted as well, but terminal 6 of IL did not appear in it... I am tempted to just remove the terminal and see what happens, but would like to know which component the terminal is connected to before hand...
Thanks though!
Old 07-05-2010, 05:17 PM   #4 (permalink)
View jeff1000's Photo Gallery
Here's the total wiring diagram for the 2005 corolla.
Hope this helps.
http://rapidshare.com/files/40517907...rolla.2005.pdf
jeff1000 is offline   Reply With Quote
The Following User Says Thank You to jeff1000 For This Useful Post:
Old 07-05-2010, 10:13 PM   #5 (permalink)
That helped me a lot!!
The terminal 6 on IL connecter went to the ECM, and when I unpluged the E6 on ECM, the AM2 amp did not get blown.
So, that is where the short circuit was!
Now, I've got to check whether if it is ECM itself or something downstream of it that has short circuit.
Old 10-09-2010, 05:38 PM   #6 (permalink)
View am_beagle's Photo Gallery
Hope this helps.
This file died.
Please help re-post it. Thanks.
am_beagle is offline   Reply With Quote
