stuck in park / locks stuck
i think i got a short somewhere or a blown fuse... but where and how?
i parked my car from coming home last night and get up the next morning and start my car. cant get it into gear and notice a bunch of my electronic components are dead. only electronic aftermarket part i have on the car is a arlarm system. its tapped into a couple of power sources and lights. also had to install actuators for all 4 doors. its been working for 4 years though.
my car is a 2004 corolla ce. automatic transmission. manual door locks.
-car starts up fine.
-car is stuck in "park". searched online and found out about the override lock button for the shifter. was able to put the car into drive and get it into the garage.
-manual door locks are all stuck on the "unlock" position. i was able to press them all into the "lock" position but they were very hard to press. the 2 rear doors lock but the 2 front doors will still open even in the lock position. i dont think the locks are controlled electronically but just in case i unhooked the battery and tried to lock the doors and they are still hard to lock.
-radio doesnt turn on. all gauge needles dont work. clock doesnt work.
-all interior lights, headlights, taillights, light up when the light switch is turned "on". havent checked to see is brake light works yet.
-i checked all fuses that were visible and they are all fine. im not sure if the enclose fuses/relays are working or not because they dont have a indicator. this is from the fuse box under the hood on the driver side. is there any other locations for fuses?
***that all the info i can think of right now. please throw out any ideas you have that i can check. ive search and found nothing. now i post and wait. while im waiting im gonna go check the wiring for the alarm and make sure there isnt a short due to the wires rubbing.
