Cant find the starter motor on my 2003 toyota corolla. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2010, 08:12 PM   #1 (permalink)
View xx-autopro-xx's Photo Gallery
Canada Cant find the starter motor on my 2003 toyota corolla.
I am haveing a hard time finding it I tried looking for it by following the posistive battery cable to where I think it is near the front of the engine (car)
can someone please tell me detailed how to find it possible post a pic of where it is.
xx-autopro-xx is offline   Reply With Quote
Old 07-14-2010, 09:17 AM   #2 (permalink)
View dorman68's Photo Gallery
This is all the info I could find from Alldata. It doesn't look like much. The starter is located under the intake manifold toward the radiator.
Home | Account | Contact ALLDATA | Log Out | Help
Select Vehicle | New TSBs | Technician's ReferenceComponent Search: Conversion Calculator 2003 Toyota Corolla LE Sedan L4-1.8L (1ZZ-FE)
Vehicle Level Starting and Charging Starting System Starter Motor Service and Repair Removal and Installation Removal and Installation STARTER ASSY
REPLACEMENT
  1. REMOVE ENGINE UNDER COVER RH
  1. REMOVE STARTER ASSY
    1. Disconnect the starter connector.
    2. Remove the nut and disconnect the starter wire.
    3. Remove the 2 bolts and starter.
  1. INSTALL STARTER ASSY Torque: Bolt 37 Nm (378 kgf.cm, 27 ft.lbf) Nut 9.8 Nm (100 kgf.cm, 7 ft.lbf)
© 2Terms of Use
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
The Following User Says Thank You to dorman68 For This Useful Post:
xx-autopro-xx (07-14-2010)
Old 07-14-2010, 09:24 AM   #3 (permalink)
Thanks alot just where I had hunched
Old 07-15-2010, 07:42 AM   #4 (permalink)
No problem. Glad to help out!
Old 07-15-2010, 12:39 PM   #5 (permalink)
View Bomix's Photo Gallery
that top bolt is a pain, I had to take the starter out 3 times because it started to cross thread.. argh!
Bomix is offline   Reply With Quote
Old 11-16-2010, 09:56 PM   #6 (permalink)
View paulstoyota's Photo Gallery
I know this is old, but the top bolt - where the heck is it? I took the one long bolt out, but the other one I'm not sure about. Is it the one in plain view that screws into the front kind of like toward the driver - as opposed to the long one on the bottom that screws in toward the driver's side wheel? Frustrating. Thx. Is there a rule against reviving old posts like this?
paulstoyota is offline   Reply With Quote
