2007 - OBD II - Communication Error!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2010, 09:51 PM   #1 (permalink)
View mfalzon's Photo Gallery
Question 2007 - OBD II - Communication Error!!!
I have a 2007 Corolla with 24k miles. I have a CEL, however i get a No Communication Error when attempting to connect via a scan tool. I'm using a Snap on Solus Scan Tool, i also brought it to auto zone to see if they can connect, No Luck.
All the fused are ok, Car feels like its running as normal.
Any help is greatly appreciated! Thanks guys!
mfalzon is offline   Reply With Quote
Old 07-17-2010, 06:03 AM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Scanner has to be CAN compliant but it is interesting that AZ cannot connect. When it comes time for emissions testing, they must connect to the OBD. Did you disconnect the battery recently or kill the battery? If so, you will need more drive cycles.
mikered30 is online now   Reply With Quote
Old 07-17-2010, 08:03 AM   #3 (permalink)
lucky I just did emissions, I disconnected the battery two weeks ago in hopes of the CEL would not return, however it returned a week later. I dunno where too start, and Im afraid toyota if gonna hit me over the head since my warranty is up.
Old 07-17-2010, 10:50 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The Snap on solus is CAN compliant so thats not the problem. Terminal 16 at the OBD2 diagnostic connector should have power to it at all times. If there is no power there take a close look at the OBD 7.5amp fuse in the fuse panel on the drivers side in the dash.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 07-17-2010, 10:56 AM   #5 (permalink)
Obd connector has power, obd fuse is good, thanks for suggestions. Any other ideas?
Old 07-17-2010, 11:03 AM   #6 (permalink)
ShawnM's Avatar
Hmm...thats a new one. Its still a fairly new car to have wiring problems, but the next step would be to check the data wires from the diag. connector to the ECM. I would think the problem has to be there given that the car starts and runs normally.
--Shawn
03 Camry LE
67 Mustang
