installing cruise control...new part numbers? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2010, 06:23 AM   #1 (permalink)
View crow's Photo Gallery
My hats off to the DIY's that worked a couple of threads to help others put cruise on our 9th gen cars.
Added Cruise Control
My question is does anyone know the new part numbers from Rockauto.com or elsewhere that match up with the part numbers from this post? I cant seem to find the cruise control switch wire. The other part numbers dont match either but I did find them.
thanks in advance.
crow is offline   Reply With Quote
Old 07-22-2010, 08:52 AM   #2 (permalink)
Gameroom cash: $105620
View wylee's Photo Gallery
Just look up a cruise control switch for an 05 Pontiac Vibe on Rock Auto's website.
2010 Corolla S 5 speed. It's GONE!
2007 Corolla CE Auto
2010 Aveo5 - good CHEAP car so far
wylee is offline   Reply With Quote
Old 07-22-2010, 06:44 PM   #3 (permalink)
thanks but I still could not find the wire suggested on the DIY thread.
Old 07-22-2010, 07:30 PM   #4 (permalink)
What wire? What post number in that thread are you referring to?
I've done this on an 05 Manual, 06 Auto, and an 07 Auto. The manual also required a clutch switch but no additional wires were needed for any of them.
Old 07-22-2010, 09:16 PM   #5 (permalink)
post number four states the following:
84633-04020 Cruise control wire (this is what connects the stalk to the steering wheel spinal)
Not needed I guess but might be easier than exchanging the horn ground wire.
Old 07-22-2010, 11:48 PM   #6 (permalink)
Ahhh...I see.
Post number 4 is instructions for what appears to be a Tacoma or Tundra. The wire is part of the switch on the Corolla, so there is no wire to buy separately.
Old 07-23-2010, 06:44 PM   #7 (permalink)
forget I started this thread. I ordered the cruise control, exchanged the ground wire, and installed it in about an hour. Works great.
It would help to have the correct part numbers but if you have patience, one will find the parts.
thanks to all for such a great site.
Old 07-29-2010, 05:21 PM   #8 (permalink)
impala409's Avatar
View impala409's Photo Gallery
Canada Cruise Control
Does anyone know of an aftermarket cruise control add-on for the 2003-2004
Corolla models, as these are not "fly-by-wire" accelerators, as in the 2005 on up.
impala409 is offline   Reply With Quote
Old 07-29-2010, 07:45 PM   #9 (permalink)
From Rostra's website:
2004 TOYOTA COROLLA - MATRIX
CRUISE CONTROL
250-1223
Control Lever: 250-3421 or 250-3742
Adapter: 250-4361
VSS Wire: LOCATION 2- 4 CONNECTOR ECM- 2ND CONNECTOR LEFT TO RIGHT
VSS Wire Color: VIOLET/WHITE
VSS Pulse: 4000
VSS Tach Wire: LOCATION 2- (E6) 31 PIN CONNECTOR OF ECM POSITION 5
Tach Signal Wire Color: BLACK
Brake Switch Positive: RED/WHITE
Brake Switch Negative: GREEN/WHITE
Click Here to view wiring diagram.
