Originally Posted by Murray Warner
Hi
I just purchased a used 2006 dark blue corolla CE. There is 124,600 + KMS . It is a 5 speed standard .A couple of questions if I may.
The dark blue paint has the sparkly flects in it and probally a clear coat. What wax is safe to use on this paint.
The windshield seems to have lottsa scratches in it most likely from scrapping ice off. Is there a product available to remove scrathes in windshield glass and lastly for now when I let off the gas pedal the engine is slow to ramp down. Is there a cure for this Thanks for viewing and thanks for anyones time to answer
Can you remove the specs? It may be the paint,, does it have mica in the paint name? Any wax is fine but stay away from Carnauba wax, it only lasts 6 weeks. Most other store waxes do not last long either.
If you want to do a great wax job and not just a good wax job, buy a clay bar and use that before you wax. Not sure what auto stores you have in Canada, but most stores should carry it. Of the store waxes, I recommend the duragloss line and collinite 476, which may only be found at marine store. Walmart down hear carries clay, if you cant find those waxes, probably the best other wax you can get Meguiar's NXT Generation Tech Wax 2.0 liquid, not the paste.
If you want to go hardcore and buy online, Zaino is great and so is klasse sealants. Those are superior to store waxes.
As for the scratches, the only product that will help very light scratches is this:
http://www.eastwood.com/glass-polishing-kit-pro.html
If your fingernail catches in the scratch, no product will help. You can only hope that a rock hits and cracks your windshield or just live with them.
What do you mean by "when I let off the gas pedal the engine is slow to ramp down."
