front disk brakes change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2010, 09:46 PM   #1 (permalink)
View fernando333's Photo Gallery
i want to change my disk brakes on my 06 corolla but dont know how does any one know were i could maybe find some instructions or like a step by step run through?
fernando333 is offline   Reply With Quote
Old 07-28-2010, 07:04 PM   #2 (permalink)
View olbus's Photo Gallery
You have PM
olbus is offline   Reply With Quote
Old 07-29-2010, 08:06 AM   #3 (permalink)
View dorman68's Photo Gallery
: Conversion Calculator 2006 Toyota Corolla L4-1.8L (1ZZ-FE)
Vehicle Level Brakes and Traction Control Disc Brake System Service and Repair Service and Repair FRONT BRAKE
COMPONENTS
OVERHAUL
HINT: Use the same procedures for the RH side and LH side. The procedures listed below are for the LH side.
  1. REMOVE FRONT WHEEL
  2. DRAIN BRAKE FLUID NOTICE: Wash brake fluid off immediately if it adheres to any painted surface.
  1. REMOVE FRONT DISC BRAKE CYLINDER SUB-ASSEMBLY
    1. Remove the union bolt and gasket from the disc brake cylinder, then disconnect the flexible hose. HINT: Gasket has 2 types: 2-piece type and 1-piece type.
    1. Remove the 2 bolts and disc brake cylinder.
  1. REMOVE DISC BRAKE PAD KIT FRONT (PAD ONLY)
    1. Remove the 2 brake pads with anti-squeal shims.
    2. Remove the anti-squeal shim No.1 and anti-squeal shim No.2 from each pad.
    3. Remove the indicator plate from inner pad.
  1. REMOVE FRONT DISC BRAKE PAD SUPPORT PLATE
    1. Remove the pad support plate (No.1) from the cylinder mounting.
    1. Remove the pad support plate (No.2) from the cylinder mounting.
  1. REMOVE FRONT DISC BRAKE CYLINDER SLIDE PIN
    1. Remove the 2 cylinder slide pins from the cylinder mounting.
  1. REMOVE FRONT DISC BRAKE CYLINDER MOUNTING LH
    1. Remove the 2 bolts and cylinder mounting.
  1. REMOVE FRONT DISC BRAKE BUSH DUST BOOT
    1. Place the cylinder mounting in a vise.
    2. Using a screwdriver and a hammer, remove the 2 bush dust boots from the cylinder mounting.
  1. REMOVE CYLINDER BOOT
    1. Using a screwdriver, remove the set ring and cylinder boot.
  1. REMOVE FRONT DISC BRAKE PISTON
    1. Place a piece of shop rag or equivalent between the piston and the disc brake cylinder assembly.
    2. Use compressed air to remove the piston from the disc brake cylinder assembly. CAUTION: Do not place your fingers in front of the piston when using compressed air. NOTICE: Do not spatter the brake fluid.
  1. REMOVE PISTON SEAL
    1. Using a screwdriver, remove the piston seal from the disc brake cylinder assembly. NOTICE: Do not damage the inner cylinder and cylinder groove.
  1. REMOVE FRONT DISC BRAKE BLEEDER PLUG
  2. INSPECT BRAKE CYLINDER AND PISTON
    1. Check the cylinder bore and piston for rust or scoring. If necessary, replace the disc brake cylinder assembly and piston.
  1. INSPECT PAD LINING THICKNESS
    1. Using a ruler, measure the pad lining thickness. Standard thickness: 11.0 mm (0.433 inch) Minimum thickness: 1.0 mm (0.039 inch) If the pad lining thickness is equal to the minimum thickness or less, replace the brake pad kit front.
  1. INSPECT FRONT DISC BRAKE PAD SUPPORT PLATE
    1. Make sure that both plates have sufficient rebound, have no deformation, cracks or wear, and that all rust and dirt are cleaned off. If necessary, replace the pad support plate (No.1).
    1. Make sure that both plates have sufficient rebound, have no deformation, cracks or wear, and that all rust and dirt are cleaned off. If necessary, replace the pad support plate (No.2).
  1. INSPECT DISC THICKNESS
    1. Using a micrometer, measure the disc thickness. Standard thickness: 25.0 mm (0.984 inch) Minimum thickness: 23.0 mm (0.906 inch) If the disc thickness is less than the minimum, replace the disc.
    1. Put matchmarks on the disc and the axle hub.
    2. Remove the front disc.
  1. INSTALL FRONT DISC
    1. Aligning the matchmarks, install the front disc. NOTICE: When replacing the disc with a new one, select the installation position where the front disc has the minimum runout.
  1. INSPECT DISC RUNOUT
    1. Check the bearing play in the axial direction and check for the axle hub runout.
    2. Temporarily fasten the front disc together with the hub nuts. Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
    3. Using a dial indicator, measure the disc runout 10 mm (0.39 inch) away from the outer edge of the front disc. Maximum disc runout: 0.05 mm (0.0020 inch) If the runout exceeds the maximum value, change the installation positions of the disc and axle so that the runout will become minimal. If the runout exceeds the maximum even when the installation positions are changed, grind the disc. If the disc thickness is less than the minimum, replace the front disc.
  1. TEMPORARILY TIGHTEN FRONT DISC BRAKE BLEEDER PLUG
  2. INSTALL PISTON SEAL
    1. Apply lithium soap base glycol grease to a new piston seal.
    2. Install the piston seal to the disc brake cylinder assembly.
  1. INSTALL FRONT DISC BRAKE PISTON
    1. Apply the lithium soap base glycol grease to the piston.
    2. Install the piston to the disc brake cylinder assembly. NOTICE: Do not screw the piston forcedly in the disc brake cylinder assembly.
  1. INSTALL CYLINDER BOOT
    1. Apply the lithium soap base glycol grease to a new cylinder boot.
    2. Install the cylinder boot to the disc brake cylinder assembly. HINT: Install the boot securely to the grooves of the cylinder and piston.
    3. Using a screwdriver, install the set ring. NOTICE: Do not damage the cylinder boot.
  1. INSTALL FRONT DISC BRAKE BUSH DUST BOOT
    2. Apply the lithium soap base glycol grease to seal surface of 2 new bush dust boots.
    3. Using a socket wrench (19 mm) and a hammer, drive the 2 bush dust boots in the cylinder mounting.
  1. INSTALL FRONT DISC BRAKE CYLINDER MOUNTING LH
    1. Install the cylinder mounting with the 2 bolts. Torque: 107 Nm (1,089 kgf-cm, 79 ft. lbs.)
  1. INSTALL FRONT DISC BRAKE CYLINDER SLIDE PIN
    1. Apply the lithium soap base glycol grease to the sliding part of the 2 cylinder slide pins.
    2. Install the 2 cylinder slide pins to the cylinder mounting.
  1. INSTALL FRONT DISC BRAKE PAD SUPPORT PLATE
    1. Install the pad support plate (No.1) to the cylinder mounting.
    1. Install the pad support plate (No.2) to the cylinder mounting.
  1. INSTALL DISC BRAKE PAD KIT FRONT (PAD ONLY) NOTICE: When replacing the brake pads, the anti-squeal shims must be replaced together with the brake pads.
    1. Apply disc brake grease to each anti-squeal shim No.1.
    2. Install the anti-squeal shims on each pad.
    3. Install the indicator plate to the upper side of the inner pad.
    4. Install the brake pads to the cylinder mounting. NOTICE: Install the brake pads in correct position and direction.
  1. INSTALL FRONT DISC BRAKE CYLINDER SUB-ASSEMBLY
    1. Install the disc brake cylinder with the 2 bolts. Torque: 34 Nm (350 kgf-cm, 25 ft. lbs.)
    1. Install a new gasket and flexible hose with the union bolt. Torque: 29 Nm (296 kgf-cm, 21 ft. lbs.) NOTICE: Install the flexible hose lock securely in the lock hole in the disc brake cylinder. HINT: Gasket has 2 types: 2-piece type and 1-piece type.
  1. FILL RESERVOIR WITH BRAKE FLUID
  2. BLEED MASTER CYLINDER SST 09023-00101
  3. BLEED BRAKE LINE
  4. CHECK FLUID LEVEL IN RESERVOIR
  5. CHECK FOR BRAKE FLUID LEAKAGE
  6. INSTALL FRONT WHEEL Torque: 103 Nm (1,050 kgf-cm, 76 ft. lbs.)
2005 Corolla LE - Impulse Red - Auto Trans - 1ZZFE - 86,000mi
2003 Echo - Auto Trans - 96,000mi. - slow as dog-dirt - I'd rather put my money in the bank than in the tank!!!!!
dorman68 is offline   Reply With Quote
The Following User Says Thank You to dorman68 For This Useful Post:
Scotty61 (07-29-2010)
