Sinking Brake Pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2010, 05:42 PM   #1 (permalink)
impala409's Avatar
View impala409's Photo Gallery
USA Sinking Brake Pedal
I own both a 2003 & 2004 Corolla CE models, both with around 110000klms.
I have noticed for some time now, when sitting at a stoplight for a long period of time, the brake pedal loses pressure and sinks under my foot, dropping about two inches. Both cars do this, and slightly lurch forward a
couple of inches. A friend of mine just acquired a 2008 Rav 4, and experiences the same thing. His pedal actually sinks farther, and then slowly drops to just above the floor.
I've bled the brake systems to ensure that there is no air in the lines, but received no improvement. Everything functions normally in daily driving, no
loss of pressure under hard braking, panic stops are normal. Does anyone else
ever experienced this problem?
impala409 is offline   Reply With Quote
Old 07-29-2010, 06:35 PM   #2 (permalink)
mikered30's Avatar
Gameroom cash: $532567
Mine does that when the ac compressor kicks on.
mikered30 is online now   Reply With Quote
Old 07-30-2010, 09:52 PM   #3 (permalink)
NMGeorge's Avatar
View NMGeorge's Photo Gallery
I've noticed that after stopping fully - like at a light - mine will do it too. Otherwise, it brakes fine... I don't think it's a problem.
George
2007 Corolla S
NMGeorge is offline   Reply With Quote
Old 07-31-2010, 06:47 AM   #4 (permalink)
impala409's Avatar
Yes. It is more pronounced when the a/c is on. If other people are experiencing this problem, please let the rest of us know. My fear is that if my attention is turned, the car could inadvertently roll forward and bump someone. This may be some sort of design flaw. I've owned other Corollas of previous model years and have never experienced this. This body style runs from 2003-2008, that's a hell of a lot of cars.
Old 07-31-2010, 11:44 PM   #5 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
This is not a problem. The brakes are powered by engine vacuum. When sitting stopped, engine idle dropping, or the AC kicking on, will cause an increase in vacuum thus causing the brake pedal to drop closer to the floor.
There is a check valve between the brake booster and the intake manifold. Any time there is an increase in engine vacuum, it increases the power given to the brake booster, and the check valve keeps this from going away when engine vacuum drops back to normal levels.
The surge forwards is from the increase in engine output that comes from the idle controller increasing idle power to compensate for the AC compressor, or other power-sapping device kicking on. Torque increases, thus making the engine more likely to overpower normal minimal braking pressure.
This will happen with any car from any manufacturer (unless the car is brake-by-wire). It should raise red flags if what you describe does NOT happen. That it is happening means everything is functioning as it should.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 08-06-2010, 11:13 AM   #6 (permalink)
View mopars&corollas's Photo Gallery
The aging of the rubber section of the brake line between the calipers and the steel lines also adds to this. It starts to allow more expansion as time goes on. Mine use to do this quite a bit. I replaced mine with braided flexible steel hoses and I dont ever have it now-
mopars&corollas is offline   Reply With Quote
