Does Shock need to be change when you changing to sport spring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-01-2010, 08:12 AM   #1 (permalink)
Offcial TN Newbie
Slaander's Avatar
View Slaander's Photo Gallery
Canada Does Shock need to be change when you changing to sport spring?
Just wondering does the stock shocks will do fine with sport springs?
2011 RAV4 I4 LTD with leather package. Used have 9th Gen Corolla with 2nd Gen Altis Tail, 2nd Gen Halo Projector, 17" Enkei RS Evolution, NEXEN N5000, AEM SRI, Vibrant Performance Muffler,Tein H-Tech
Springs
Slaander is offline   Reply With Quote
Old 08-01-2010, 11:23 AM   #2 (permalink)
on full afterburner
Gameroom cash: $1346597
Yes. But they will blow out faster and are not meant to run compressed.
If it's a mild drop then it would be fine.
Old 08-01-2010, 06:59 PM   #3 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
i did the rear and doing the front tomorrow, at the rear is nitrogen shock, didn't see the brand on it tho.
update: got the front done, and those OEM shock is made by KYB
Springs
Old 08-03-2010, 10:07 AM   #4 (permalink)
SKIPPY911
View skippy911's Photo Gallery
How low'd you go ?
03 Rolla-K&N Intake-Front Tower Brace-5mm wheel spacers-15" Steels-3 Baby Seats-Limo Tint-Driven Hard Daily
skippy911 is offline   Reply With Quote
Old 08-03-2010, 07:35 PM   #5 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
Originally Posted by skippy911 View Post
How low'd you go ?
Tein H-Tech Lowering Springs 2003-2008 Corolla
Lowers 1.7F/1.8R
Springs
Old 08-03-2010, 08:22 PM   #6 (permalink)
RC1
Gameroom cash: $372892
View RC1's Photo Gallery
Canada
1" to 1 1/4" drop is no problem on stockers as long as you don't have a lot of miles on them and you don't slam the upper mount into the top of the shock. If they are getting weak now, the drop springs will generally eat them up because the shock can't stop the spring motion from cycling. The shocks don't know whether they're compressed or extended, so the old tale of wearing them out because they're compressed is just that, an old tale.
RC1 is offline   Reply With Quote
Old 08-03-2010, 08:28 PM   #7 (permalink)
Offcial TN Newbie
Slaander's Avatar
Canada
any suggestion for replacement?
here is info on the spring
Description:
TEIN High.Tech springs utilize the latest spring and material technology to optimize comfort, performance, and quality. Designed and tested in North America to be used in conjunction with OEM or similar shocks for excellent ride comfort and slightly increased handling. The line is produced with Vanadium (SAE9254V), which is durable, lightweight, and has properties to retain more spring stroke. High.Tech springs are designed for those seeking a slightly lowered stance while maintaining high ride quality at a reasonable price. Most vehicles will attain a 1.2 inch drop for a more attractive appearance, added performance, and excellent comfort. Includes a one year limited warranty.
Additional Features:
• Chrome Vanadium SAE9254V Construction
• Progressive Spring Rate Design
• Includes Silencer Rubber on certain applications
• Gold Powder Coat Finish
• Developed to be used in conjunction with OEM or OEM replacement dampers • 1-year Manufacturers Defect and Sag Warranty
Covers over 5mm sag, breakage, deformity, and noise. Does not cover powder coat finish and rusting.
(front) 1.73"
(rear) 1.81"
Springs
Old 08-03-2010, 10:01 PM   #8 (permalink)
RC1
Canada
You may be pushing it a little at that amount of drop on a stock strut/shock. You could try it and just look at the clearance from the top of the strut body. Try sliding an o-ring over the shaft of the strut before you button everything up, it will act as an indicator by sliding up the strut and letting you know how close it gets to the top. If I had to guess, I'd say you will replacing the struts. Have a look at Koni red/yellow, probably your best bet.
