2008 Corolla CE 1.8L (Ram Air with stock intake piping)
You will need a
1.Rachet
2.10 mm socket
3.Extension about 6''
4.2 clamps big enought to fit around piping
1. Take out your battery.
2. Open air box and take out your air filter.
3. You will see 3, 10mm bolts remove them.
4. You will see 1, 10mm bolt down by the front of where your battery was on the intake piping, remove it.
5. Now it is kinda tricky but remove the air box and intake piping.
6. After you have it all apart you will find stapels holding the breathable piping to the plastic remove them.
7. Turn the breathable piping downwards and turn the elbow towards front of the car.
8.Place all back togeather and you piping should be right behind your fog light.You can eather take out your light cover for better breathing or leave it there. Ether way it will be getting cold air other than hot air off the rad.
