You are well out of any warranty unless it was bought used and came with a warranty. A TSB is a technical service bulletin. It is not a recall, but it informs customers with problems with a car and how to fix it. There was a 60K mile warranty on that fix, but you are well past that and the fix is on you. On the TSB, a potential fix is to replace the ECU, along with some other items. I am not sure what Toyota will do in November when you bring your car in for the ECU recall. They will see the engine light, and then scan for the code, likely at your expense. There will be some sort of protocol, but I dont know what it is. You can hold out until November when you get the new ECU or wait, but I dont know if that will cause any problems with the tranny, but you said it was on and off for a year. If you have inspection in the next 2 months, it will not pass with that light on.
Cut and past from the TSB:
TSB number TC008-04
Title:
M.I.L. "ON" DTC P0741
Models:
'04 - '05 Corolla (1ZZ-FE)
November 22, 2004
Introduction
Some 2004 - 2005 model year Corolla vehicles may exhibit M.I.L. "ON" with DTC P0741 (Torque Converter Clutch Solenoid Performance). Production changes have occurred to correct this condition. Follow the repair procedure to address those vehicles that exhibit the condition.
NOTE :The repair procedure must be followed closely to assure that only the affected part is replaced, as multiple possible causes are listed.
Applicable Vehicles
^ 2004 - 2005 model year Corolla vehicles equipped with 1ZZ-FE engine produced BEFORE the Production Change Effective VIN shown below.
SO THAT MEANS BEFORE VIN # 1NXBR3#E#52369427
Production Change Information
Warranty Information
Applicable Warranty*:
R & R of the Speed Sensor, Transaxle, and Torque Converter Clutch Assembly are covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle's in-service date.
R & R of the Engine Control Module is covered under the Toyota Federal Emissions Warranty. This warranty is in effect for 96 months or 80,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
