Battery problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2010, 08:39 PM   #1 (permalink)
View khrystsina's Photo Gallery
Battery problem
2004 Toyota Corolla 4 cyl Front Wheel Drive Automatic 75000 miles
I replaced the battery in my car about a year ago. Lately I have noticed that my clock in the car is not lit up as well sometimes. Today I tried to start the car and it made many clicking noise similar to when you press the button on your remote to open/close the car. Also, the speedometer was going crazy showing that I was going 10-20 miles/hour even though the car was parked. The lights flickered and turning the car off (taking the key out of the ignition) was the only thing that stopped this craziness. When I jumped the car, it started perfectly. What could that be?
khrystsina is offline   Reply With Quote
Old 09-22-2010, 08:44 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $615331
View Zembonez's Photo Gallery
Dead battery?
Zembonez is offline   Reply With Quote
Old 09-22-2010, 08:48 PM   #3 (permalink)
Originally Posted by Zembonez View Post
Dead battery?
I changed the battery only a year ago!
Old 09-22-2010, 08:49 PM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Means exactly nothing. A 2 day old battery can be discharged. You need to start with the basics and have the battery checked. What you describe sounds EXACTLY like a dead battery. Maybe the charging system is not doing its job.
The Following User Says Thank You to Zembonez For This Useful Post:
khrystsina (09-22-2010)
Old 09-22-2010, 08:51 PM   #5 (permalink)
Even flickering lights when the car isn't on? I will get the battery checked I guess, and if it's fine, I'll have to check the charging system. Thanks for the response!
Old 09-22-2010, 08:54 PM   #6 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Yeah. I really am trying to help. A low battery can cause all sorts of odd electrical behavior. You might want to check the cables and make sure they are good and tight too.
Good luck!
Old 09-22-2010, 11:25 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1346597
If you have access to a multimeter, test if the alternator is working by running a load test on your battery.
If it checks out then all you may need is a recharge.
Tags
battery, electrical, jump
